Failed to parse a grace LSA. If the LSA is self originated, the grace period requested from neighbors prior to restart may not be discovered, and the default used instead. Otherwise, we may not act as a helper neighbor for another restarting router.
No action required - Notification message only.
Notice
Failed to parse an LSA. The fields below supply more information on this problem. Advertising router %p1% Incorrect length %p2% Incorrect value %p3% Mandatory TLV not present %p4% Repeated type %p5%
| Name | Type |
| p1 | DecByteArray |
| p2 | sInt |
| p3 | sInt |
| p4 | sInt |
| p5 | sInt |
